i have code 12 lean oxegen sensor ? whats up?
Old Nov 12, 2001 | 12:28 PM
AudioDEO's Avatar
Car: 89 Formula 350
Engine: a Big one
Transmission: I dont keep them long.
im getting code 13 when i cruise for like 50 mile drives. it trips the code for a few minutes and then stops what do i need to do?
thanks...
[This message has been edited by AudioDEO (edited November 12, 2001).]
Old Nov 12, 2001 | 01:34 PM
AudioDEO's Avatar
Car: 89 Formula 350
Engine: a Big one
is this the wrong place to be posting this?
Old Nov 12, 2001 | 01:59 PM
20-psi's Avatar
Code 12 is the stopping and starting code for my TTA. Code 13 is for the O2 sensor. It sounds like it is not setting off any codes.
Pete
Old Nov 12, 2001 | 04:24 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Code 12 is "all OK". You have a temporary code that doesn't record into the computer. If it doesn't stay, then that means that at the point the check engine light goes off, the problem that would set the code is not causing any more problems. You need to scan for the code when the light is constantly lit. If your only getting it while crusing, that sounds like it would be a VSS, but that's code 24. Good luck, and if everything is running good other than a light, don't worry about it.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Nov 12, 2001 | 08:50 PM
AudioDEO's Avatar
Car: 89 Formula 350
Engine: a Big one
im sorry im a idiot its 13 not 12 ...
somthing about an o2 sensor....
what should i do..
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
