car takes insanely long time to warm up!
Ok, when I go to start my car in the morning, it takes like 4-5 minutes before it is fully warmed up and idleling at around 700 rpms. I think this is way to long. I'm willing to wate 1-2 minutes, but this is getting rediculous (sp?) What can I do to make it warm up faster? My eninge is a fully stock LG4 and I just had a new choke pull-off put on.
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Bridgestone Potenza RE730 255/45ZR17 all around
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Pioneer head unit
Kenwood speakers
Now KYB equipped!!
Car: 4
Engine: 6
Transmission: 5
4-5 min is about right. Choke pull-off has nothing to do with warm-up time, it simplyu allows full massive enrichment for intial start-up, then leans it it out a little to keep it from blowing black smoke and all that from being too rich once it gets running.
ICON Motorsports
ICON Motorsports
Matthew,
Do you have the E4ME carburetor (electrically heated choke)? If the choke heater is not working, it can take an "insanely long time" to warm up. Make sure there is 12VDC to the choke heater when the engine is idling (oil pressure switch is closed). If not, start looking at the auxilliary oil pressure switch, choke fuse, and wiring. Meter the heater element for continuity.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Later,
Vader
Car: 91 Red Sled
You think that is a long time, lol
For a while my car wouldn't warm up...ever, turned out to be a broken thermostat (robertshaws break in the open position).
Now that I fixed the thermo the engine starts and warms up in about 3-4 minutes and that's with my fan on with ignition.
Do you still have a functioning heatriser?
Ghettobird52
Jul 5, 2024 11:18 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
