hot air source from headers, is it possible?
Old Nov 13, 2001 | 05:55 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
hello guys.
winter is comming fast and i,ve installed headers on my 87, 350, 4bbl rochester, camaro (yes its a mod, from 2.8 crap to 350 carbureted)and i wanna know if somebody knows of anything i can do to get a hot air source for the carb heat, is there any aftermarket adaptor or something?
thanks guys.
Fernando.
third gen muscle power is the only thing that can match the power of flight...
Old Nov 13, 2001 | 05:58 PM
82camaro's Avatar
Car: 82 camaro SC
Yes I've seen them, but I don't know where to get them. It works just like the stock hot air intake except it hooks onto the headers. You could probably make something.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 13, 2001 | 08:33 PM
breathment's Avatar
autozone has some sort of factory air intakes for carbed cars, with heat riser tubes, i don't know how well they will work, might wanna check it out, they are usualy on top of the shelves near the air filters.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 13, 2001 | 08:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The stainless edelbrock headers on my truck came with a stove pipe adaptor. There's no reason why you couldn't fabricate something similar.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
1992 Trans Am
May 10, 2023 07:19 PM
dyeager535
Aug 28, 2015 08:10 AM
theurge
Aug 21, 2015 12:46 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 11, 2015 03:17 PM
