Pistons
Old Nov 14, 2001 | 08:54 AM
Jason 85 IrocZ's Avatar
Pistons
Hello,
I am rebuilding my engine again and would like some suggestions on what pistons to get or if I should kept the stock ones. I do have a budget, so nothing too expensive.
Its a supercharged 305 TPI. Also any suggestions for a manifold?
Jamieson
2000 NBM TransAm WS6 #485
85 Blue Super Charged Iroc-Z28 Camaro
79 TransAm
1999 Oklahoma Gathering
2000 SWMG
2001 SWMG
Old Nov 14, 2001 | 10:06 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
I don't know what to tell you about intakes. However, on a budget I would look at a set of flat top hypereutectic pistons. They're in between stock and forged. A great piston for an engine on a budget.
Jason
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns w/baffles removed, Throttle body airfoil.
"The reason most import drivers only focus on looking fast is so they can sit there staring at their car and dream about it being fast, because there's no way for them to match American muscle."
Old Nov 14, 2001 | 10:50 AM
iroc5speed's Avatar
for supercharged aplications make sure you get pistons that will keep the compression reasonably low, shouldn't be more than 9:1 in my opinion
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Nov 14, 2001 | 11:00 AM
85transamtpi's Avatar
I agree about the compression ratio. Keep it low if it is a supercharged motor. What kind of supercharger are you running? How much boost?
Old Nov 14, 2001 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For supercharged or NOX applications, forged are really the way to go. The hypereutectic are cast using a different alloy than what is used for what is normally called "cast" pistons, but are actually not as good for power adders as stock cast.
Forged are by far the best for your application. Cost should not be the basis for your decision.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2200 stall TC. Ported World 305 heads, Crane PowerMax cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip, Spohn SFCs. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited November 14, 2001).]
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
