TPIS Miniram installation, defective manifold?
Old Nov 13, 2001 | 11:32 PM
383TAGTA's Avatar
Car: 1987 GTA originally 350TPI 3.27posi
Engine: 383 C.I.D.
The mechanic assembling my engine ran into a problem when installing the Mini-ram manifold. It doesn't seal at the back curve "S" part by the distributor. This is a major casting error and I'm very dissapointed with TPIS specially for $895. It apparently was given a sharper curve and cut too much into it that the back of the manifold does not seal. This was proven by a beautiful oil leak when the engine was spun on the stand. I have AFR 195cc heads brand new out the box so I know for the a fact its not the heads causing some sort of distortion. I just want to know if this is fairly common and there's a fix to this. I'm using 1205 Felpro intake gaskets that were professionally port-matched to the heads. I would lose the $200 I paid for the port-matching of the heads to the intake gaskets and manifold if I return it. We have arrive at two possible solutions. One to use a very thick gasket or to weld the piece of aluminum needed to seal the manifold properly. We tried calling TPIS but no Tech's were available so he's calling first thing tomorrow morning. Has anyone experienced this or heard of this sealing problem or was I one of the lucky ones to receive a bad batch of defective manifolds?
If anyone could shed some light into this matter or has any experience installing a Miniram please share your insight. I'm definently dissapointed with TPIS quality.
Old Nov 14, 2001 | 05:30 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
No one I know uses gaskets to seal that area. Use RTV, preferably black GM sealer. Throw those gaskets away that come in the intake gasket kit.
But you wouldn't know that if you had a mechanic put your intake on.
Also if it was defective casting, what would you loose on the port matched HEADS? You said you paid $200 to gasket match the heads so what does returning the Miniram have to do with that?
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
[This message has been edited by John Millican (edited November 14, 2001).]
Old Nov 14, 2001 | 12:40 PM
rezinn's Avatar
Exactly how much of a space is there between the base and the block? It should be about or less than 1/4" iirc, and that seals up nicely with silicone. Orange or black will do fine. I have three of those little curvy gaskets adhered to my garage door back at home.
As long as it is the correct height to allow the distributor to sit properly, it can be sealed up fine.
Old Nov 14, 2001 | 01:50 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
TPIS's quality blows, that's for sure. I've helped install 2 miniram's, and both of them had their own little problems.
Nothing with the sealing though.
Compare it to your stock intake bottom to bottom to be sure that it is not the right shape.
Old Nov 14, 2001 | 01:52 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I am also using AFR heads and a MiniRam II. Fortunately I do not have an oil leak at the back of the intake, but there is not much material around the oil pressure switch.
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
