Attn: Accel supercoil owners, where did you mount it?
Old Nov 14, 2001 | 10:36 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Originally I had the Accel coil mounted to the firewall behind the distributor, and it was really close to the dist. Now with the new motor mounts it's actually hitting the dist cap, so I clearly can't put it there. I'd like to use the coil wire that came with my MSDs, so that gives me about a 10" radius around the distributor in which to mount the coil. So where the heck am I supposed to put it? Has anyone made it work with the factory coil bracket? (I haven't seen mine in two years)
91 Z28
Come see The Vicious...
Ah, I forgot to mention, it's a 91 TPI.
[This message has been edited by ViciousZ (edited November 14, 2001).]
Old Nov 14, 2001 | 11:07 PM
TPortFormula's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: a crappie 700-R4
try mounting it on the left (passenger side) of the distributor cap, about where the ground wire from the engine is bolted into the fire wall. Its the wire with no sheeth, with a small wire w/ a sheeth. You'll probably have to relocate the ground, further down the fire wall. I saw this on my neighbors IROC. I don't know how the crap he did it, but he did, so it is possible.
Vintageracer
Jan 10, 2020 05:33 PM
tazs2000
Jul 15, 2017 08:44 AM
deracer
Apr 11, 2016 12:04 AM
BAMiller
Sep 14, 2015 06:38 PM
hydrolic144
Aug 29, 2015 04:14 PM
