coolant leak below crank pulley
Old Nov 12, 2001 | 04:20 PM
88camaro's Avatar
after this one time the car overheated ,when i get out in the morning i have a wierd coolant leak from where the crankshaft pulley is located , i beleive its coming from the water pump, but it never did it before it overheated , and i recentley rebuilt the engine ,so i donno why would it do that . and how can i correct it
and after i start the car the coolant stops leaking for the rest of the day , but when i get out in the morning it leaks again.
my car is an 88 camaro 2.8 mpfi w/t 5 spd manual,(i donno if that helps ,but in anycase)
Old Nov 12, 2001 | 10:41 PM
85 Berl's Avatar
That does sound like the water pump. It's the only thing I can think of in that area.
Old Nov 13, 2001 | 01:00 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Yeah, sounds like the water pump to me too. Sometimes they'll be leak-free around the shaft seal when the engine is warm, and the cooling system pressure helps the shaft seal up nicely. But overnight, when everything cools down, and the pressure bleeds off, it starts leaking. Been there done that.
HEY!! - Post number 180!! Wahoooooo!!!
-1983 L69 Camaro Z28 305 H.O. (Bored .030 over,Teflon oil seals,Melling H.V. oil pump,Hyperetic pistons,chrome-moly rings,2040 Crane compu-cam) T-tops, 3:73 Open rear, BW T-5, Rebuilt E4ME 4 Barrel, Duel Snorkle Air Cleaner w/K&N Filter , Rhino Clutch, Crane 2040 Compu-cam, LS1 valve springs, porting, PST front end kit. Now for paint, interior, etc...etc.... Also:
2000 S10 4.3L 4WD LS
1995 Ford Thunderchicken, 4.6 V-8
[This message has been edited by Confuzed1 (edited November 13, 2001).]
Old Nov 13, 2001 | 05:21 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
-nm
[This message has been edited by JMatlock88 (edited November 13, 2001).]
Old Nov 14, 2001 | 05:55 PM
88camaro's Avatar
confused1 wht did u do to solve this problem .
can i do it without replacing the pump
and if i have to replace it what would u think it'l cost me
thnx for the help every1
Old Nov 14, 2001 | 06:35 PM
82camaro's Avatar
Car: 82 camaro SC
pump replacement required. Call around to get some prices.
Reminds me of a funny story. A ol' farm boy(nothing against farmers) welded the weep holes shut on a SBC water pump to stop the leaking.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 14, 2001 | 11:17 PM
iroc5speed's Avatar
get in the area with a flashlight. It could be coming from a hose, or even from the water pump gasket. if it's the gasket, just replace that and spare the expense of the pump.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
