whats this connected to the cooling system ??
Old Nov 14, 2001 | 10:12 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
I believe its connected to the 2 heater core hoses that go through the firewall, and it has a third hose that goes directly to the throttle body, it's some sort of plastic black valve, i need to know what it's called so i know what to ask for, i broke it while doing some engine work.... Thanks guys !!
Old Nov 14, 2001 | 10:34 PM
rezinn's Avatar
Try "heater valve"
Old Nov 14, 2001 | 10:36 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Heater control valve
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 14, 2001 | 10:58 PM
TPortFormula's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: a crappie 700-R4
yeah, definetly the heater valve. i broke mine too at one point. you'll find one at napa. Becareful putin it back on. new one just as weak as original. try lubing the hose ends up on the inside a little bit and also where the hoses connect on the valve. that worked out good for me. don't use too much though.
Old Nov 14, 2001 | 11:42 PM
breathment's Avatar
ya, broke mine right after doing the TB bypass, they get pretty warm and don't handle stress very well.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 15, 2001 | 09:39 AM
Trent257's Avatar
you dont need it, just run the firewall to the intake, and cap the hose with the t-end, all the heater valve does it flow the coolent when heat is on, and blocks it when the heat is off, without the valve, it just runs the coolent all the time
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 15, 2001 | 10:51 AM
91Z28's Avatar
Car: 91' Z28
Thanks for you help guys !
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Slush92RS
Sep 2, 2015 08:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
