Why doesn't my fan start?
Old Nov 15, 2001 | 12:26 AM
DAHULK2000's Avatar
I never figured out why my fan all of a sudden stopped working. I checked the fan motor, it's still good. My car's temp will start going up, and the fan won't kick in. Can anyone help me out 92 Firebird 305 TBI. Thanx! I'm new at this!
92 Firebird 305 TBI
K&N Open Air Element
K&N Crank Case Filter
Just a begginer, soon i will advance!
Old Nov 15, 2001 | 09:30 AM
Trent257's Avatar
you prolly need a coolent fan sensor, dont get it at autozone, they gave me the wrong one, and take it with you just to be sure, its in between the 6th and 8th cylinder, has a wire comming from it
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 15, 2001 | 10:36 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yeah, fan switch (sensor) or fan relay located between master cylinder and fender on driver's side of firewall.
-Rich-
Old Nov 15, 2001 | 10:46 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Look hears how you'll know. Start your engine and turn on your A/C if the fan comes on it's your temp sensor that's bad. It's located on the passenger side right under the manifold, it has a single wire conector.
If the fan does not come on with the A/C then its the fan relay located on the driver side of the fire wall. If you look you will see 2 small black boxes next to each other the fan relay is the one closest to the fender.
Mark
Old Nov 15, 2001 | 01:07 PM
88camaro's Avatar
mine does the same thing , so i just put a switch in , and when i think its warm enough i just switch it on , and everything was fine till now
eightsixseven
Dec 16, 2024 01:50 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
