Engine Bay and Block paint
Old Nov 15, 2001 | 08:04 PM
70GTO's Avatar
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
I've got the engine out of my car and the engine bay looks pretty sad. The car is a red/maroon metallic. The bay is painted the same color but, it really looks"thin" as if it needs more of the base color and has never had any clear coat applied. What color do I paint it? Black maybe? I would really like to paint the block Chevrolet Orange ( I think orange blocks with aluminum heads and intake look great), but I don't want the two colors to clash. Help me out here, I'd like your opinions!
Thanks, Bruce
"Four on the floor, fifth in the glove compartment"
Old Nov 15, 2001 | 08:11 PM
leirch's Avatar
Here you go. I had the same delima,
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Nov 15, 2001 | 08:25 PM
70GTO's Avatar
Car: 89 Iroc Z
Lerich, That looks great and is definantly an option,but I wonder if an orange block will clash?
Old Nov 15, 2001 | 08:51 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ah, Leirch...
"And the only thing that was left from the old engine, is the oil spot on the cement"
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
