Holley Overdrive Transmission Braket...
Old Nov 15, 2001 | 02:18 PM
yOp 84 Recaro's Avatar
I have a Holley 750 on my 84 305. It always has jumped like crazy between 1st and 2nd. I was told that I need a overdrive transmission braket made by Holley. So I went and bought one. Now how do I put it on (I see where it goes, but im not sure what is to happen with the old transmission braket that is in there already). And seconly how do I get the kickdown cable on properly (I was told it was a 2 man job).. Any help would be much appreciated...
Old Nov 15, 2001 | 09:36 PM
82camaro's Avatar
Car: 82 camaro SC
The problem isn't usually the bracket. Where the cable connects to the throttle linkage is different on the holley and has a shorter thow. When you set the TV cable to be maxed out at full throttle(like it should be), the TV cable becomes pulled too far at light or no throttle. The tranny thinks you have your foot in the throttle when you actually don't. I think you can get a arm to correct the problem. I just live with mine.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 15, 2001 | 11:04 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It's made by Sonnax. You can order one through a tranny shop.
http://www.sonnax.com
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
