Oil Pressure sending unit problem
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
About a month ago I was having problems with my oil pressure, I kept reading low. First thing I did was jack up the car and check the sending unit. when I unpluged the connector from it I noticed that oil was leaking from the back of it where the plug slides in, so I replaced it. Now I have a new sending unit in and it's leaking again from the plug connection. Is this a normal thing, it doesn't seem like it would be.
Mark
Mark
might help if you said what kind of car/engine combo. there is a sender by the distributor and above the oil filter on a SBC in third gens.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 91 Camaro RS
Engine: 305 TBI
it's a 91' camaro 305 TBI. I'm refering to the oil pressure sending unit located on the side of the oil filter mount.
<font face="Verdana, Arial" size="2">Originally posted by grafx:
it's a 91' camaro 305 TBI. I'm refering to the oil pressure sending unit located on the side of the oil filter mount.</font>
Car: 91 Camaro RS
Engine: 305 TBI
switch, sensor, whatever it's what sends the signal as to how much oil pressure there is. And no I have an actual pressure gauge.
My question was is oil suppose to be leaking from the back where the plug slides in? It's not a bad leak but you can see that there is oil coming out where the plug is.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
If it's leaking, it's bad.Replace it.I've seen 'em leak like that, but usually are not accurate when they're leaky.Mine used to show about half of what my mechanical gauge read, and sometimes it would be close to actual.Seemed really random, but after replacing it, accuracy was better and leaking stopped.Still, I rely on mechanical gauges now for water temp and oil press.
-Rich-
-Rich-
Car: 91 Camaro RS
Engine: 305 TBI
yeah I just replaced it and after replacing it the acuracy returned but now the new one is leaking just like the old.
Ghettobird52
Jul 5, 2024 11:18 PM
