Code 45.....
Old Nov 17, 2001 | 11:31 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Code 45.....
Code 45 came up, O2 sensor rich. Now in the past i've thrown a code 13..which went away...now the code 45. What can cause this all of a sudden? MY injectors are on their way out...holds pressure when running but takes about 10 seconds to lose all pressure after turning the car off. So what do u guys think it is? The bad injectors, bad O2 or the ECM(i've thrown a code 13 and code 42 like 2 months ago, did nothing about it and they haven't returned, now i have a code 45, maybe the ECM is bad?)
What do you guys think???
TIA
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Nov 17, 2001 | 12:55 PM
fly89gta's Avatar
Car: 2018 Camaro SS
well, part of the problem was the ECM, see i wasn't hitting closed loop AT ALL, thats taken care of, now can ****ty injectors cause me to run rich? i heard that injectors that don't spray correctly messes up the atomazation and cause the fuel to not entirely burn...any further help would be great
Old Nov 17, 2001 | 01:10 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If between your "setup" (injectors & fuel pressure) and the "calibration" in your eprom, the ECM cannot correct (it is limited to BLM/INT of 108/80) - then you will throw a Code 45 - Rich O2.
So YES, bad injectors that are leaking can cause this.
Old Nov 17, 2001 | 04:33 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Thanks man,i figured that the injectors would cause the problem, i'll try to swap them out ASAP
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
