megashifter parking cable?! help!
Old Nov 17, 2001 | 08:24 PM
Garett92Z's Avatar
Hey everyone...
in the process of installing megashifter... it's 90% done... one thing!
The car starts in every gear.
where does the right hand side "Parking cable" go on this thing?!
I looked through instructions it didn't mention anything about this.
Any help would be apreciated.... pls be quick if you can i'm stranded til i get this fixed!
Garett
Old Nov 17, 2001 | 08:34 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
It doesn't attach to the shifter... you unhook it from the old shifter and put it in the full forward position and leave it there. I believe your problem with starting the car in every gear is due to the micro switches on the megashifter... or lack there of. Instead of hooking up the micro switches on my megashifter, I detached the big device on the right side of the shifter with all the wires on it and left the lever on it in the park position and stuffed it under the console out of the way. Saves time cutting and splicing wires and adjusting the micro switches but since the lever is in the park position the car with start regardless of what gear the megashifter is actually in.
WejaZ28
Oct 3, 2015 07:38 PM
///DAN///
Sep 25, 2015 02:15 PM
camaronils
Sep 20, 2015 02:57 PM
dbrochard
Sep 19, 2015 08:13 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
