head and cam question
Old Oct 21, 2005 | 06:27 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
I am planning on getting some heads and a cam for my gw 350. I was gonna p&p some 416's but i would rather just get some aftermarkets. Within 2 years i'm planning on buying a 383 shortblock so i want to be able to use the same heads if possible.
My cam will be a Crane 222/222 .467/467
I'm looking at the Trick flow K.D. heads with cnc'd chambers and
these Patriot heads. http://www.patriot-performance.com/w...p?x=1&DID=1225
The patriots come with guideplates and screw in studs.
Will a holley street dominator intake work with these heads?
Will a holley 4160 600cfm carb be enough?
I will also be getting rockers, double timing chain and new pushrods.
thanks for any info.
Old Oct 21, 2005 | 09:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you buy the Trickflows I would get the standard heads and then have them worked over by someone who knows what they are doing. Your money will be better spent and you will have some awesome heads.
I will be doing this shortly on my 2nd rebuild. Going for well over 400HP with TPI on a 355. I will report the results.
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
