low CR and high boost, or high CR low boost?
Old Oct 22, 2005 | 12:03 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just wondering what would be better, to have a very low compression ratio and run an insane ammount of boost or run a fairly high CR and a low boost.
I guess it would all have to do with the flow of the heads and cam specs but in general anyone know which would be better?
Old Oct 22, 2005 | 02:29 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
For a motor that has to run on street pump gas you'll make more power with a motor that has a low compression ratio and more boost than a high compression ratio motor that willl not allow as much boost without detonation.
Old Nov 5, 2005 | 05:50 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Youll get more peak power out of a motor with high boost and a lower compression ratio. Youll get a flatter torque curve out of a motor with high compression ratio and low boost.
Old Nov 5, 2005 | 08:14 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Agreed with dankhound: If it's a strip-only car, run ~7:1 compression and 20+ psi boost. If it's street-only or street/strip, run 8:1+ and ~10 psi boost. When I get the money for my TT 383, I'd like to run 8:1 and 15 PSI boost.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
