rpm,s up
Old Oct 23, 2005 | 11:31 AM
thirdbirds's Avatar
Car: 87gta 88notch 89 5spdgta 92 vert
Engine: 5.7
rpm,s up
ok, have a question? i have tbi. when you turn on the heat,defrost,or air. it revs up and idles back down ? can feel this while at low speed what is the problem ?anyone ! thanks
Old Oct 23, 2005 | 01:19 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
no problem, the ecm adjusts for the increased load. It's normal
Old Oct 23, 2005 | 01:20 PM
what part of ohio are you from?
Old Oct 23, 2005 | 06:04 PM
thirdbirds's Avatar
Engine: 5.7
brookville. just down the road from you !
Old Oct 23, 2005 | 10:36 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
Re: rpm,s up
normal, its your a/c clutch clicking on and off, it goes away after about 5 minutes of normal driving, not a big issue at all.
Old Oct 24, 2005 | 05:43 PM
thirdbirds's Avatar
Engine: 5.7
ok thanks! are you guys sure ? this thing will lunge forward with the brake on at a stop !
Old Oct 24, 2005 | 07:09 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
It could be that its because the car is cold and the fact that the a/c clutch is chiming on and off, if you drive it for about 5 minutes it will stop doing that and drive normally, its nothing serious...
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
