heater core
Old Oct 23, 2005 | 12:52 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
heater core
what's the best way to bypass a heater core without having hoses running all over looking stupid?
Old Oct 23, 2005 | 01:09 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Follow the hoses back as far as possible towards the water pump and either remove the two hoses and replace with a short piece of hose or cut them and use a coupling and a couple of clamps.
Old Oct 23, 2005 | 01:14 PM
i saw a pic somewhere that there were no hoses at all. I don't know if they just plugged the intake and waterpump and took the thermostat out or what they did.
Old Oct 23, 2005 | 01:22 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
grab a couple 1/2" brass plugs to put in the intake and waterpump. Its a hella lot nice looking than a piece of hose running across the 2 for no reason. You might also be able to find chrome plugs if you like the bling.
Old Oct 23, 2005 | 01:33 PM
that wouldn't be good for the pump to push against a closed thermostat would it?
Old Oct 23, 2005 | 01:36 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I have no heater core at all and plugs in the intake and water pump. It's a high flow Miloden. No problems at all.
Old Oct 24, 2005 | 03:35 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
I took the two hoses off the firewall and connected them with a 6" piece of brass pipe. Tighten up two clamps and your good to go.
FYI.
Getting those hoses off the firewall was a chore. They were seared on there pretty good. 17 years and lots of heat from the engine.
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
