new cam and high pitched noise
Old Oct 25, 2005 | 12:12 AM
cmeyer's Avatar
Car: 70 Camaro RS
I could use some help.
I installed a new cam and lifter set last week and while breaking in the cam, I got a rattling noise like I had a bad lifter. To make a long story short, I pulled the cam to find one of the cam lobes worn way down and the corresponding lifter was trashed.
I just installed another new cam and lifter set this week. No more lifter noise, but there is a suttle, yet annoying, high pitched squeek that speeds up with engine speed. It's difficult to tell exactly where the noise is coming from, but it's definitely coming from mid engine on back (not an accessory noise). I'm thinking either cam bearing or distributor gear.
Can a cam bearing make a real high pitched noise or just a knocking sound?
Has anybody experienced a similar noise from an old distributor gear?
Any thoughts?
Chris
Old Oct 25, 2005 | 08:57 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What year is the engine? On some of the older 70's engine they had alot of mismachined blocks with misdrilled starter bolt holes and lifter bores that dont point at the cam.
Old Oct 26, 2005 | 12:01 AM
cmeyer's Avatar
Car: 70 Camaro RS
The engine is a GM crate stock replacement engine with about 70,000 miles. I put the engine in myself about 10 years ago.
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
