Fiberglass Front End???
Old Nov 19, 2001 | 10:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I was looking at the JC Whitney site and they sell the complete fiberglass front end for camaros. But it says 82-84, what would be the problem with putting it on my car. And would it really be worth the $600 for the saved weight when there are other mods I could make. How much weight would be saved. Then there would be the cost of painting it, which I should just get the whole car painted then.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 19, 2001 | 10:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The year range is just the early style. It'll work on all third gens. Harwood sells a fiberglass front end based on the 92 style.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Nov 19, 2001 | 10:48 PM
Enkil's Avatar
I was looking at some stuff from American Sports Car Design, and they said the same thing, that it fit an 82-84. I emailed them about it, and they said there were some small differences in the bodies, but that they'd be very little effort on the part of the shop installing them.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Nov 20, 2001 | 12:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have an entire front clip from an '84 on my 1986 (with the correct '86 bumper), and it all fit up. I believe you might not be able to use your existing "steel" bumper, though, with a flip-up front end.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 20, 2001 | 01:23 PM
SoCo80p's Avatar
dont forget that those glass front ends are NOT a bolt on, you must custom make brakets to mount them and also no really the best idea on the street eather, even if you nailed a *****, the ***** would win, fiberglass will shatter on even a light impact
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
Street Lethal
Apr 30, 2019 12:14 PM
bellez77
Sep 5, 2015 08:39 PM
