350 build
Old Oct 26, 2005 | 01:21 PM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
350 build
well right now im starting from scratch, i have a mid 80's 350 4 bolt main thats already been bored .030 over. unsure if i want to stroke it? but its most likely going to be a 11 to 1 motor. open to all suggestions
Old Oct 26, 2005 | 01:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
This is way too vauge.
Old Oct 26, 2005 | 01:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you already have a good rotating assembly, go ahead and build a 350. If you need to replace it, build a 383.
Old Oct 26, 2005 | 01:47 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Instead, sell it and get a 400
Need more details it sounds like you have a 30 over block but just a 30 over block. Doesent let us know if it's a fresh bore or in the past it has been bored.
Old Oct 27, 2005 | 12:27 AM
Car: 85 camaro
Engine: 327
sorry, no its not a fresh .030 over.
Old Oct 27, 2005 | 01:05 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It'll need to be checked then to see if you can get away with just honing it, or if it needs to be bored and new pistons put in.
If it does need new pistons, that's a great excuse to spend a little extra on a new crank to build a 383.
Old Oct 28, 2005 | 01:15 AM
Car: 85 camaro
Engine: 327
well, things have changed. looks like im going with a big block instead.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
