Porting my intake?
Old Nov 20, 2001 | 08:58 AM
Gta-Paladin's Avatar
Porting my intake?
I've got headers and an exhaust, now untill i can afford to buy that miniram... I'd like to breathe a little better. It's my understanding that the intake and runners are the bottleneck here. What i want to ask is, is it that hard to do? I've got no experience, wait i have less than that. I feen like an infant with a dremel. Should i port it myself? Is it that difficult? What problems can i run into? How will i know once i've ported enough? How much can i expect from a good port and a 52mm tb.
When does need a 58mm tb?
- There are no dumb questions, just inquisitive idiots.
Old Nov 20, 2001 | 09:28 AM
19WS6T/A91's Avatar
Im not really sure about the porting but i do know that you do not need a 52mm TB. The stock 48 with a air foil should hole you over for quite a while. I have heard that the stock TB with a air foil will hold you until you are pushing 400+ horespower.
Old Nov 21, 2001 | 12:17 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I consider this an extreme example, but I ported the heads and TPI intake on my first 350 engine, and gained 40 HP at the rear wheels.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
