Will this bolt up?
Old Nov 21, 2001 | 04:08 PM
BowtieFever's Avatar
Will this bolt up?
will a pontiac 327 bolt up to a 73 nova or a 88 iroc camaro
92 Camaro RS
305 TBI
T-Tops
DynoMax Cat-Back Exhaust
Gutted Cat
Hypertech Street Runner Chip
K&N open element
Custom Interior
Window Tint
Prestige Alarm
Foglights
JVC El-Kameleon Head Unit(w/ remote)
Pyramid 6 x 9's
(bass blockers)
Jensen 5 1/4's
2- 10" Kenwood Tornado Subs
Pyramid 600 Watt Amp
Best ET: 15.976 @ 86.01 mph
reaction time: 0.479
60 ft: 2.269
Old Nov 21, 2001 | 04:12 PM
85transamtpi's Avatar
You need different engine mounts and a transmission adapter. You may want to check with the motor swap board for more specific info.
Old Nov 21, 2001 | 04:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
For the Camaro you'll probably need a different flywheel.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 21, 2001 | 04:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pontiac never made a 327. They did however make a 326, which will not bolt up to a Chevy trans, exhaust, or anything else. It is the same external size (bulk!) as all other Pontiac V8s, so it doesn't have a very attractive CID-to-weight ratio.
They may have used a Chevy 327 in some of their cars at some time but I don't think so.
If it's a 327 it will bolt into either the Nova or Camaro, but you will have problems if you want to install accessories, if its heads don't have the bolt holes in the ends of them.
Is this a Pontiac motor or a Chevy motor? Do you know how to tell the difference?
ICON Motorsports
Old Nov 21, 2001 | 05:42 PM
SoCo80p's Avatar
it will fit into eather no problem, the 73' nova would be a bit easyer of a swap, all you have to do is get a trans adapter plate and the motor mounts and its ready to bolt in!
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
