redline on a 383
Old Nov 21, 2001 | 11:58 PM
jptaylor2's Avatar
redline on a 383
what would be an approximate redline on a 383.
jptaylor
Old Nov 22, 2001 | 12:09 AM
Enkil's Avatar
That depends on what parts the engine's built out of.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Nov 22, 2001 | 12:21 AM
cort351w's Avatar
I was wondering pretty much the same thing. How do you know what your redline is after you change your engine displacement?
Old Nov 22, 2001 | 02:55 AM
Enkil's Avatar
The redline on a car has to do with the strength of the cars internal parts, like rods, pistons, crank, etc. After I got the redline for that figured out, THEN I would find the redline of the engine's power. (So, if I had an engine that had an engine rated to 7000rpms, but only made power to 6000rpm, I'd shift at 6000 even though the engine could safely rev higher, since it'd be useless to do so.)
89 iroc-z 305 tbi
Old Nov 22, 2001 | 09:00 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by Enkil:
</font>
I agree with Enkil. You should think that there are two redlines - one that the engine can mechanically handle (based on the internal parts) and the other based on where the max power occurs.
Mechanically, you want to make sure the top end (valve springs, etc) can still make power without having "valve float" occur, then that the bottom end will hold together at that RPM.
I currently have a friend with a 383 and a Miniram that makes max power at 6,000 rpm and the engine was built to handle 6,500 rpm. The Miniram will allow the engine to rev way past 6,000 rpm, but since the cam selected was designed to make it's max power at 6,000 rpm, it does not make much sense to rev the engine past 6,000 rpm.
If my friend was to select a cam that allowed him to make max power above 6,500 rpm, my friend would have to relook at his engine's bottom and top end to support those higher rpm levels.
Basically, the cam (along with matching intake and heads) will determine where you make max power. The engine's internals will determine if the engine can handle it, without something failing.
Old Nov 22, 2001 | 11:47 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
very few 383s make peak hp above 6000. It takes lots of head flow.
Old Nov 22, 2001 | 12:53 PM
SoCo80p's Avatar
big cube moters do not need to spin to the moon to make power like the smaller engines, the 383 and 400 make all its power right off the bat and make tons of chassis twisting torque, they will be hauling right away, unlike a 350 or smaller there just getting started at about 3,3,500 RPM
[This message has been edited by TempesT68 (edited November 22, 2001).]
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
