Help my friend decide... GTO or third gen trans am
Old Nov 26, 2005 | 12:30 AM
  #51
rwdtech's Avatar
Car: 1991 Z28 (sold)
anyone hear about the Ford GT oil leak problems?
Old Nov 26, 2005 | 08:33 AM
  #52
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
I don't care if it leaks or not, it's hot. and I love the mid engine design. if I could afford one I could afford to put oil in it. My firebird leaks a very small amount of oil, but I don't care. it's not even enough to leave a drip on the ground.
Old Nov 26, 2005 | 12:19 PM
  #53
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Only thing I know about the GT40's is they had the safety recall regarding their control arms, new forging.
Their solution was to run billet blocks through CAD, and have the replacement control arms made this way. Each control arm is worth 1,200 dollars
Get a third genereation car. Modify it your way. Heck you can even have the entire interior made custom, not like one would cut up the interior on a brand new car.
My rule has become, if the car has a distributor get it, if not well think harder.
Old Nov 26, 2005 | 12:35 PM
  #54
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Originally posted by zippy
i've done flash programming on obd 1 vehicles using the moates system. this does work well and make programming just as easy as the obd 2 vehicles. you are still stuck with software that is by far outdated and mass air systems that max out if i recall around 330gms. you are also stuck with a pcm which is much slower and has less capability. with the GTO people have installed gen III engines as large as 455 cubes pumping out well over 500rwhp and run the stock pcm with mearly modified programming. if you tried that with the third gen mass air computers you'd have had to convert it to speed density since it isn't capable of reading anywhere near the airflow numbers of an engine putting down some real power. obd2 computers also allows for trans programming including shift points, line pressure adjustments, shift timings, etc. you can program a dry nitrous system to work flawlessly and retard the timing on it's own when the nitrous is used. the transmission programming capabilities alone are enough to make it worth it to me. i've been doing programming for paying customers for quite some time and i've worked with both obd1 and obd2 systems and even the in between versions. without ever pulling the engine 11's are capable from the GTO (not including nitrous or boost) with drivability as good or better than a stock one. that isn't even a thought for a third gen.
Mine will read up to 512 g/sec with the stock ecm on my third gen.
Plus my car is capable of running mid 11's on slicks (times in sig on DR's) and its a bone stock unopened long block. So both those statements are not entirelly true.
Old Nov 26, 2005 | 12:45 PM
  #55
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Well if your friend is really into 3rd gens. tell him to get the 3rd gen. i bought an 05 GTO in late June and its a great car but its nothing like a 3rd gen. sure there easy to work on but parts cost twice as much then any 3rd gen parts. stuff for the LS2 are just coming out, like blowers and tuners.
plus enless he has money he wont be able to mod the GTO for awhile.
i still want to get another 3rd gen over the GTO.
Old Nov 26, 2005 | 06:32 PM
  #56
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Having both a 3rd gen and a GTO myself i would say get the GTO if money is available. The GTO is so much more refined then any 3rd gen.
You don't have spend $30K for a GTO if you are a smart shopper. I didn't. I got an '04 with 400 miles on it for $21K. Just last week an '04 GTO with 19 miles sold on ebay for $21K also I believe. The 2004's came with the LS1 rated at 350HP. A very nice engine indeed.
The 2005's are slightly more, some as low as $26K but you must shop around and be willing to pick it up maybe out of state and drive it home. They got the LS2 which is 400HP but mods are slow at coming.
Old Nov 26, 2005 | 07:06 PM
  #57
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
thats one hell of a deal you got on yours i paid $30k when they had the gm emplyoee discount. i got mine with 54 miles on it.
trust me if i had the chance id sell the gto for a super clean 91-92 z28 or rs
Old Nov 26, 2005 | 07:35 PM
  #58
damn they're gorgeous cars. I think gm ought to come out with a tempest line and put a 3.8 or something it and price it competively with the mustang v-6. They could then build some sales up with a base car
Old Nov 27, 2005 | 12:15 AM
  #59
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
The new GTO's just dont do it for me. I would rather have a WS6 or SS. The GTO's just look like regular cars in my opinion,until you see the decals. I have ridden in one and believe me they are quick
eightsixseven
Dec 16, 2024 01:50 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Reddeath210
Oct 6, 2015 08:20 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
