HELP, bad idle, hesitation
Old Nov 1, 2005 | 04:37 PM
staleyracing's Avatar
Car: 1992 Z28 Camaro
Engine: TPI 5.7liter
My idle will speed up after a hesitation. It will goto between 1500-2000rpms when in park. Its like a serge, it will dip down and then idle up. Ive cleaned the TPI (throttle body), changed the TPS, Ox. Sensor, Plugs and wires, cap and rotor. and I cant find any vacuum leaks anywhere. All the hoses are in good shape. I put in a new fuel filter. To top it off there isnt a SES light code so im open for new ideas. Thanks
Old Nov 1, 2005 | 10:46 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
how did you look for vacuum leaks? i chased a similar problem for about a month and didn't hear any vacuum leaks. the vacuum guage read within specs for vacuum. i found a vacuum leak this weekend with carb cleaner. fixed it and idles great now. so, just cuz you don't hear a vacuum leak doesn't mean it doesn't exist.
Old Nov 2, 2005 | 08:56 AM
How did you use carb cleaner to find the leaks?
Old Nov 2, 2005 | 12:07 PM
87zjeff's Avatar
sprayed all the vacuum lines. i heard it bubble and the engine stumbled a little when i found it. then, to be sure, i played with the hose and heard the idle fluctuate(sp?) a little bit.
xxx3man`
Sep 23, 2015 10:37 PM
db057
Aug 22, 2015 08:17 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
