question but rockers
Old Nov 24, 2001 | 02:16 PM
FstBrd6point3's Avatar
ok, so I wanna get a set of roller rockers for my car, but my mechanic is telling me that I can only use the crane gold rockers on tghe cam set-up that I am suing, but the max list if only .480. . so shouldn't I be able to use any 1.5 ratio rocker?? also, I have the center bolt valve covers, does this make a difference?? I am not to knowledgeable with valve train components, so if anyone can help me out that would be great. I ask mainly because as much as I want my car to have only the best parts I real don;t have the extra 300 to buy the cranes when I can get ones form summit that sound to me like they are exactly the same for 150. . . thanks for the help
1987 Pontiac Firebird Formula 350
1 of 2,384 made, Black with Silver decals
350 TPI
700R-4 Tranny with TCI shift kit and Corvette servo with TV boost sleeve
TCI saturday night special 2200-2500 stall converter
WS6 supsension
SLP headers with full 3" exhaust exiting through an SLP dual 2.5" tip muffler
SLP airfoil
180 degree thermostat
hypertech "performance" chip
3.73 rear
Viper talkin alarm with remote start
My 383 is in the process of being built right now, hopefully to make it's debut by middle December. . . many more mods to come in the summer. . maybe some experimentations with juice. . have some track times my independence day.
Old Nov 24, 2001 | 02:35 PM
ede's Avatar
ede
you need SA rockers but crane isn't the only ones you can use. comp makes SA rockers, pn 1317 for 1.5 ans 1318 for 1.6. i'd buy the 1318s if it were me.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 24, 2001 | 02:40 PM
rezinn's Avatar
Normal full roller rockers will not work, you must use crane golds or some other expensive ones. If you want the best parts without going that expensive, get yourself a set of comp cams chromemoly roller tipped rockers. I really don't understand your ratio question; the max lift is calculated with a certain type of rocker, with 1.6 it would be higher... Some rockers will not work for you.
3.8TransAM
Sep 3, 2015 06:38 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
