Injectors, PROM and more
Old Nov 21, 2001 | 10:15 PM
Iroc n roll's Avatar
I am putting an LT1 intake and cam on an 1987 L98. What size injectors should I use with this? L98 #22? LT1 #24? Also, I know my car will benefit greatly from a custom burned PROM but will my car be able to run for a while on the stock one?
Old Nov 24, 2001 | 09:29 PM
Anybody?
Old Nov 25, 2001 | 09:20 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by Iroc n roll:
I am putting an LT1 intake and cam on an 1987 L98. What size injectors should I use with this? L98 #22? LT1 #24? Also, I know my car will benefit greatly from a custom burned PROM but will my car be able to run for a while on the stock one?</font>
have fun putting the intake on. it's not a direct bolt on. use the #24 injectors. it should run fine. maybe a little rich.
Old Nov 25, 2001 | 03:16 PM
Yes, I realize that its not a bolt on. Does anyone know if the stock chip is going to handle this at all?
Old Nov 25, 2001 | 04:12 PM
Guest
Guest
Posts: n/a
If you run the 22# injectors with it, yea it will work fine. There is always room for improvement with a custom prom, but thats the case with just about any car.
Old Nov 25, 2001 | 05:12 PM
Thanks man, that's what I needed to know.
92-Formula
Dec 12, 2015 10:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
