Guess My Weight
Old Nov 5, 2005 | 04:55 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Guess My Weight
Who wants to take a shot? (Im just bored and curious)
88 Hardtop Camaro
350 with Aluminum heads, no A/C or Emissions assecories. Pretty much everything not needed for a carb setup has been taken out of the engine compartment. Auto tranny. 1/4 tank of gas and my skinny 130 pound ***!
Then possibly a fiberglass hood, and is gutting the doors worth anything realy?
Old Nov 5, 2005 | 05:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
3200
Old Nov 5, 2005 | 06:38 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
my guess would be 3400lb'ish (with you in it). Get a set of lightweight wheels with skinnies and a glass hood and you'd lose quite a bit...
Old Nov 5, 2005 | 07:07 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
my registration says it weighs 3124 pounds, aluminum pulleys, water pump, heads, intake.. i got fiberglass hood, i wonder how much this would drop the weight?
auto, carb, no smog accessories, only front seats on the car, 17" aluminum rims
Old Nov 5, 2005 | 07:53 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Re: Guess My Weight
88 Hardtop Camaro
Sounds like my setup, except I'm 125 lbs!! And 6ft. Got you beat
No a/c, heat, smog, complete engine harness is gone, heater and a/c ducting under the dash is gone, TPI setup is gone, just a carb, front swaybar gone, no rear seats, power steering pump gone, and 430hp, ought to run ok.
Old Nov 6, 2005 | 07:58 AM
Shake Zula's Avatar
If I have enough money Ill also do skinnies and tubular K-member, cuz I wanna pull the front wheels
Old Nov 6, 2005 | 09:18 AM
Dialed_In's Avatar
Hell with that nonsense, get the thing to leave straight and get a good ET out of it. I've got draglites rears and skinnies, but I have to run a "street" tire on the front to run in my local bracket class, so I've got DR's on my GTA's.
Old Nov 6, 2005 | 02:52 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
Re: Re: Guess My Weight
6' 125lbs? how do you lift the wrench to work on your car??
Old Nov 7, 2005 | 11:13 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
Re: Re: Re: Guess My Weight
probably needs a cheater bar at all times
Old Nov 7, 2005 | 11:15 AM
Your car weighs exactly what a scale says it weighs. Not one pound more, not one less.
Guessing is a waste of time and bandwidth. Go take it to a weigh station by the side of the freeway, or to the track, and find out the truth. Nothing else matters.
Old Nov 7, 2005 | 11:41 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
True that
Old Nov 7, 2005 | 01:33 PM
JesasaurusRex's Avatar
Re: Re: Re: Re: Guess My Weight
Old Nov 7, 2005 | 06:39 PM
Dialed_In's Avatar
You'd be surprised.
Linson
Oct 24, 2025 02:00 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
