383 piston/ring question.
I'm planning a 383 and am gathering parts. I have 60cc 6085 edelbrock aluminum heads, and an 87 roller 350 block thats going to be bored over .030, I'm looking at some
Keith Black pistons, they are 12cc d-dish, going to use 5.7 rods also. Can anybody tell me what ring size I need to use with these? I can't find any info on any other webpages. 1/16 rings right?
Thanks,
Brendan
1987 IROC-Z, engine, tranny, and other "stuff"
Thanks,
Brendan
1/16" is good guess but i don't know for sure and don't have a KB catalog. whoever sells you the pistons will know for sure. you want to make sure the pistons work for a 5.7 rod.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Guest
Posts: n/a
Those have 2 5/64" rings and 1 3/16" ring.
Just for kicks:
They are for a 383 with 5.7 rods. The compression height is 1.433, pin diameter .9272, 12-cc D-cup (probably look identical to the ones I have), the pistons are 515 grams, and the pins are 145 grams. They recommend .0015 clearance piston-bore.
I also tracked down their website, this page has some ring info for ya:
http://www.kb-silvolite.com/page53.htm
I'd use the speed-pro rings personally.
The ring listings probably are missing the oversize FYI.
[This message has been edited by madmax (edited November 25, 2001).]
Just for kicks:
LT1Formula
Oct 8, 2015 08:34 PM
