Question about vortec heads and accessory brackets
Subscribe
Nov 26, 2001 | 01:36 AM
I have an 82 camaro with the v-belt accessory system. A/C is on the driver's side up high. If I switch to an engine with vortec heads, all the accessory holes will still line up properly right? The bracket I'm mostly concerened about is on my a/c. There is a support rod that bolts to the top of the a/c bracket and the second bolt of the intake manifold. The vortec heads eliminated some bolts from the traditional style intake bolt pattern right? Is this bolt still in the same place or fairly close?
The Sumbitch is Broken
82 Camaro:350, Erson cam, ported heads,Comp Cams 1.6:1 rocker arms, Edelbrock Performer RPM intake, Holley 600cfm,
TH350 tranny with 2500 stall, Eibach Pro Kit, SLP 1 3/4" headers with 3" Flowmaster exhaust
Reply 0
Nov 26, 2001 | 04:01 PM
The intake bolts on Vortec style manifolds
are vertical to the ground ( angled in the heads) and in a different position. That would require you to modify your A/C support
bracket to anchor it on one of the intake bolts.
Reply 0
Subscribe
