Knock Sensor Info
Old Nov 7, 2005 | 08:36 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Knock Sensor Info
On the '730 equipped cars, is there still an external ESC module, or is that in the Memcal?
In other words, if I were wiring up a knock sensor, would I simply run a wire from the sensor to pin B7?
Old Nov 7, 2005 | 09:13 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Its in the memcal.
Should be a few wasy posted about using the old sensors with the new system thru resistors and the sort.
Not sure if it applies to the v6 cars however.
later
Jeremy
Old Nov 7, 2005 | 09:41 AM
Doward's Avatar
My engine was originally a 2.8/MAF system... I pulled the 2.8 and the MAF system, and am wiring a 3.1 into place, and I want to be sure that I just run a wire from the knock sensor to the ECM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
