Checking valve size with heads on engine, possible?
Car: 1994 Trans Am
Or would I have to completely remove the head from the block?
Why I am asking is because I have 305 heads on a 350 block and would like to to know if there is a way to decipher between stock 305 valve size and a larger than stock valve size without actually removing the head.
Can I measure the width of the valve with a micro or something like that?
Car: 1994 Trans Am
I was kind of thinking maybe with the valve cover off, I could measure the top of the valve by the keeper? But guess not.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
you could always take off the intake and the headers and look down the ports. you wouldnt get and exact measurement, but i bet you could probably get a pretty good idea. and if not, youre halfway to removing the head anyway.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you could view inside the combustion chamber you could compare the space beween the intake and exhaust valve in the head , with another stock 305 head with stock valves.
larger valves would have less space between them. 2.02x 1.60 valves almost touch.
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
