camshaft ID casting numbers??
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
I got a camshaft I pulled from a 305 block id #"S 551.
The cam is a flat tappet hyd. type with the numbers #960 towards the end by the distributor gear with D21 above that and #27 towards the cam sprocket.
what is this cam and how do I( find that out? I have been searching and its getting me nowhere.... please help
thank you very much Ryan
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Don't know about 551; but 155 is the last 3 digits of the part # of the roller version of the "peanut cam", as found in TBI and LG4 and some 305 TPI motors.
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
I dont know what engine block you have...
551 was the last three digits for 2 305's
first one was a non roller
86-87 2 bolt main
the seond was a roller
1987-1995
I am checking for your camshaft at GM
86-87 2 bolt main
1987-1995
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
intake is a tpi. heads I dont know. the engine was probably original to the car 86. I was trying to figure out the cam profile to in fact figure out if I removed the stock 86 cam.
thanks for the help so far...ryan
3.8TransAM
Sep 27, 2015 08:37 PM
tcflint
Sep 27, 2015 05:58 PM
