Porting Head. Have ?
Old Nov 7, 2005 | 10:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
How much material can I remove off the bump where the pushrod slot goes though on Cast 083 heads? Can I remove it all and smooth it around or should I not touch it? Thanks!
Old Nov 8, 2005 | 12:47 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You can open it up quite a bit but you can't nor do you need to remove it completely. The port wall is approx 1/4" thick. +/-
Use common sense. The push rod pinch is not actually a restriction to intake port air flow until the rest of the port is done completely.
armybyrd
Sep 28, 2023 12:16 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
