Physical block differences between two piece and one piece seal
Old Nov 26, 2001 | 09:45 AM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Besides the obvious crank and flexplate differences, what else is different about them. Do both have provisions for a knock sensor, etc. I finally found a rebuildable 350 short block, but I want to make sure it is compatible. I currently have a 1986 IROC with the LG4 and I want to put a 350 in it. Some of the rebuild kits I have found say "to 1984" then others say "87 and up"
Thanks,
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old Nov 26, 2001 | 10:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, all else is the same.
THe knock sensor goes in the pass side coolant drain hole. All SBCs since 1955 have had the same hole in the same place so there's no possibility of a problem there.
ICON Motorsports
Old Nov 26, 2001 | 11:20 AM
Car: 1986 IROC
Awesome, that's what I needed to know.
Thaks,
Mark
Old Nov 26, 2001 | 09:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '86 was kind of a bastard, having the one-piece rear main but still the old flat tappet cam. The kit assembliers don't like one-year-only kits, so they don't list them.
Not sure why '85 would be left out.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 26, 2001 | 10:19 PM
poncho9789's Avatar
The only other diff. is that on the front of the cam/lifter oil galarys is that the plugs for a non onpiece block has press in plugs like freese plugs and the one piece blocks have screw in plugs for those oil gallarys.
Old Nov 27, 2001 | 01:57 AM
Guest
Guest
Posts: n/a
Not really. I've had to tap every roller block I have had my hands on, they all had press in plugs.
Pretty sure the oil pan is different.
Old Nov 27, 2001 | 06:55 AM
poncho9789's Avatar
thats wierd mine did have the screw in plugs for the front oil gallarys.hummm*
Old Nov 27, 2001 | 08:08 AM
Car: 1986 IROC
As far as the oil pan then, is the pan itself different so I will just use mine, or is the mounting face different?
Mark
Old Nov 27, 2001 | 09:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Blocks up to about 1980 had the oil dipstick on the left. Starting in about 77 or 78 they began to move them over to the right. This is not a 1-piece RMS vs. 2-piece RMS issue though. There are lots of 2-piece blocks in the world that have the RH dipstick.
The oil pan is different, and the block is different where the pan goes. The pans definitely DO NOT interchange. The difference is easy to spot; if the block is for a LH dipstick, the tube plugs into the block on the head deck and comes out the bottom, with a section of the pan flange bulged out to include it, and the pass side pan flange is straight. In a block with RH dipstick, there is a small protrusion of casting near the pan flange where the tube goes, the pan flange has the bulge to include that, and the driver's side flange is straight.
This has nothing to do with the rebuild kit, only the gasket set (and the pan if your block doesn't come with one).
ICON Motorsports
Old Nov 27, 2001 | 11:09 AM
Car: 1986 IROC
This is why I love this site! You people know everything! Thanks for your help!
Mark
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
Jake_92RS
Jan 28, 2020 10:37 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Reborn756
Sep 4, 2015 03:42 AM
