porting then polishing tpi--what do I need besides intake gaskets?
Old Nov 27, 2001 | 05:08 PM
cort351w's Avatar
I am going to port the inside and polish the outside: What else besides intake gaskets do I need to put the tpi back on? Are there gaskets between the throttle body and the plenum? plenum and runners? runners and base?
Do any of you know which torx bits are required?
Old Nov 27, 2001 | 05:41 PM
irocbsa's Avatar
Gaskets go between throttle body and plenum (you can usually reuse that one, I do), plenum and runners, runners and base. Just buy the Felpro TPI upper intake gasket set from the parts store. Will have everything you need plus a few extras like an IAC gasket.
bsa
Old Nov 27, 2001 | 05:46 PM
cort351w's Avatar
thanks, irocbsa
Old Nov 27, 2001 | 06:18 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by cort351w:
</font>
i think its T45. but it might be T40.
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Jake_92RS
Aug 11, 2015 10:39 AM
