Troubble Polishing Intake...help
Old Nov 26, 2001 | 09:40 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I need with the final touch on this intake
ok well it looks pretty good but I cant get these "haze"-like lines to come out...It looks like the buffing wheel I'm using may be the wrong type... "too hard or something I dunno" What am I doing wrong?
What type of wheel is the best to use to put that last touch glass finish?? ...
Thanks for any info
Also where is a good place to get a deburring wheel?
Hecubus
Check out my site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~ 175-200hp shot/ 255lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Pro-Built stage 3 700 R4/ACT 2400 stall converter/Trans-Go shift kit
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Nov 26, 2001 | 09:48 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The one and only time I polished an intake I used a "scotch brite" type pad on my dremil.
That worked great.
SSC
85 Camaro, 355/400 "drag car" current DD 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firebird, 355/350, as soon as the powertrax gets installed. "dyno time"
Old Nov 26, 2001 | 09:57 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Dang ..he he he
well I guess that works too
how many bits did you go threw j/k
no I"m using a 8" bench grinder I dont rember the rpm "it more then enough though"
Any help on the way I'm doing it now? Oh yea what compound do you like using ?
Hecubus
Old Nov 28, 2001 | 12:09 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
can anyone give me any good tips ?? I cant get rid of these "haze" lines ...am I using wrong wheel?
Hecubus
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
