Hypereutectic piston to bore clearance??
Old Nov 27, 2001 | 11:03 PM
PerthZ28's Avatar
Engine builders - what clearance should I run with a set of Speed Pro hypers in a 4.02 inch bore? Does 0.001 to 0.0015 sound right? I am measuring 0.0025 right now but some stuff I have read says it should be tighter than that.
Old Nov 28, 2001 | 06:16 PM
ede's Avatar
ede
i'd check with speed pro to see what they say, but guessing i'd look for more clearance since hyper pistons transfer a lot more combustion heat to the piston.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 28, 2001 | 08:56 PM
Guest
Guest
Posts: n/a
Hyper pistons usually call for less clearance since they dont expand as much as other pistons do. You should contact speed-pro though to see what sort of spec they have, every manufacturer has a spec all their own.
FormulasOnly
Jul 23, 2018 08:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
91 SrS
Oct 7, 2015 04:32 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
