Hydraullic roller to just hydraullic cam.... will it work???
Old Nov 26, 2001 | 07:28 PM
speedtendancy's Avatar
i have a 88 LO3 TBI
if i swap the stock hydraullic roller 415/430"cam
and try to put a 440/454" hydraullic cam
in it and change the stock roller lifters
to hydraullic lifters will this work???
Help me out Chevy guys....
Speed
Old Nov 26, 2001 | 07:39 PM
checkeye's Avatar
it should, I have a 90 roller block in a truck that has plain hydraulic lifters, you may want to check and be sure that the lifter bore is the same.
I think the only difference is the bores are taller.
You will need to change the push rods too, think roller push rods are .100" shorter.
Old Nov 27, 2001 | 01:46 AM
Guest
Guest
Posts: n/a
The timing chain gear is different as well.
Why take a step backwards?
Old Nov 27, 2001 | 06:35 PM
<font face="Verdana, Arial" size="2">Originally posted by madmax:
</font>
Hydraullic roller cams cost a bitch and
im on limited funds
Old Nov 27, 2001 | 07:03 PM
Z28fromItaly's Avatar
But you can keep your stock roller lifters and pushrods. If you go back you'll need to get new sets and the total cost will be pretty much the same.
Old Nov 27, 2001 | 07:29 PM
<font face="Verdana, Arial" size="2">Originally posted by Z28fromItaly:
But you can keep your stock roller lifters and pushrods. If you go back you'll need to get new sets and the total cost will be pretty much the same.</font>
But where can i find a decent priced roller
camshast all the ones ive seen are at least
$250..... i live in Cali anyone have any connections or sources???
Old Nov 27, 2001 | 08:23 PM
Guest
Guest
Posts: n/a
http://www.sdpc2000.com/cart.asp?act...d=989&pid=8354
$150
.446/.450 lift with 1.5 rockers.
You may have to tap the pin back that goes through the timing gear, but it fits fine otherwise.
[This message has been edited by madmax (edited November 27, 2001).]
Old Nov 27, 2001 | 10:33 PM
$150
</font>
I just went to that site but i cant find the cam 446/450" that your talking about the LT4
cam is the the one that pops up....can you find that cam on there for me...thanks bro
Old Nov 27, 2001 | 10:44 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Something else to consider: your computer may not like the hydraulic cam. At least that's what I've heard, don't know if it's true. You would really do better just to get the roller cam. The price will come out to be about the same anyway, after you exchange all the parts. And roller cams are better anyway.
91 Z28
Come see The Vicious...
Old Nov 28, 2001 | 04:06 PM
DM91RS's Avatar
Car: 91 RS
I have the LT4 cam in mine and it works well.
Just push the pin in until it does not stick out through the timing gear too much. All of your other valvetrain parts will work with this cam and it will not screw up the tuning. I did add some fuel with the chip as I burn my own but from what many people on here say you can just tune it with fuel pressure adjustments.
I bought my cam at Jim Pace Parts online for $140 if I remember correctly.
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
Old Nov 28, 2001 | 06:46 PM
<font face="Verdana, Arial" size="2">Originally posted by DM91RS:
</font>
Thats 476"L a the intake right??
Hows your gas milage right now?? I might get this LT4 cam your talking about... I tried that siye cant get thruogh do you know the exact web address??www.???.com
[This message has been edited by speedtendancy (edited November 28, 2001).]
Old Nov 28, 2001 | 09:00 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by speedtendancy:
</font>
Thats the one I was talking about, the spec they show is with 1.6 rockers. With 1.5's its the number I listed.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
BrianI
Aug 9, 2015 11:52 AM
rsrmoore
Aug 7, 2015 08:44 PM
