Name that component!
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Okay, would anyone be able to tell me what this is?
It's found over top of the passenger side valve cover, right behind AC condenser.
What do you mean it's got the wrong connections? Should this be hooked up, because it's been out since I put in new headers and its been okay.
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
It is the diverter valve asembly that goes to your A.I.R. system. Not needed for performance but required for a visual inspections of emissions equipment..
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Name that component!
. Thread Starter
Re: Re: Name that component!
Originally posted by Supervisor42
It's called an "AIR diverter valve" It directs the output of the AIR pump (also called the smog pump) to the catalytic converter and exhaust manifold ports or to the silencer (round black can at end of hose). Looks like someone who was taking off the "smog" stuff got in a hurry and didn't throw it far enough out of the engine compartment
. Thread
