code 54
Old Nov 26, 2001 | 12:49 PM
Vikingbrew's Avatar
code 54
i dont have a book, so someone please tell what it is and how to fix.
there's no replacement for displacement
Old Nov 26, 2001 | 03:39 PM
ihateallmustangs's Avatar
fuel pump relay circuit.
Old Nov 27, 2001 | 12:25 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Means the voltage to the fuel pump was low for a second. it could mean the wiring is going bad or the connection to the ECM or the FP relay or the FP itself. I have this code intermittently too and its a bitch to diagnose ( had the problem for 5 years! )
Old Nov 27, 2001 | 01:02 AM
Vikingbrew's Avatar
oh......thats fakin great...
thats what i want to here...
Old Nov 27, 2001 | 03:11 PM
88 IROC BOB's Avatar
Had the same problem. I replaced the ecm and the problem was solved.
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Nov 27, 2001 | 07:35 PM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
I noticed that the guys who said they have this problem too drive 88's. I got that code and had my mechanic look at it. He said that his computer (don't know how) said that it is a common problem in 88 camaro's, corsica's, and beretta's......I was told I would have to drive with it until something broke to the point of no longer working to be able to tell exactly what was wrong with it or I could shell out the cash and replace ever part of the circuit
Old Nov 28, 2001 | 09:06 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I got a code 54 just before my fuel pump died. I think it's just a coincidence that you all have 88s. It is very common on TPI cars actually.
Also, high fuel pressure (50psi or higher) will tend to burn out your fuel pump quicker. But the fuel pumps on these cars are not exactly the best. I know guys with less miles on their car than mine, and they are on their 3rd pump.
Old Nov 29, 2001 | 12:39 PM
Vikingbrew's Avatar
mines an '86 though. the code only comes on at a start, never when driving. you still think its the fuel pump?
Old Nov 29, 2001 | 03:42 PM
No, I still say its the ecm. When you start your car you probably don't hear the pump come on right away. That's why the 54 sets--ecm doesn't sense any voltage to the pump. Only after the oil pressure comes up will it build any fuel pressure.
I am stilling sticking with the problem being the ecm.
Bob
Old Nov 29, 2001 | 05:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Viking, you've got an '86, eh? Exactly what would you give me for a code 54 chart?
Hey, I'll run a bonus today- visit this old message, I've typed it up already. It's from my '86 GM service book, and you can trace all the wires easily. If all the wires come out fine, then it's probably your ECM. The message is at: https://www.thirdgen.org/messgboard/...ML/001981.html
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 30, 2001 | 10:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Well considering the 86 and 88 use the same ECM...
Anyway, that code will happen from a bad fuel pump relay or from a bad ECM, or the wiring between. The relay is the cheapest and easiest thing to replace. You don't even need to buy anything. Swap it with the MAF Burnoff relay that's right next to it and see if it still throws a 54 or if it now throws a 36. That'll tell you whether it's the relay or the ECM.
You can also use a digital multimeter to test it. Set the multimeter on the thin green wire that goes into the relay. This is the wire from the ECM. If you've got voltage for a few seconds after you turn the key, then it's probably not the ECM (Or it's at least functioning properly but still throwing the code). To test the output of the relay, put the DMM probes across the two fat wires to the relay. One is power and one is ground (I forget which is which, but it doesn't really matter) and if the relay is working, you'll get +12 or -12 volts on the meter depending on which probe is touching which wire. Whatever you do, don't use a test-light to troubleshoot this.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 30, 2001 | 11:26 AM
86TransAmTPI's Avatar
I also had the same problem.I changed the fuel pump relay and it solved the problem.I got my fuel pump relay for like $12.
86 Trans Am 305 TPI,Bored 30 over,Blower Cam,Fordged Racing Pistons,High Volume Oil Pump,3" Flowmaster Exhaust,Hypetech Coil,Acell 300+ Race Wires,Bosch Platinum +4 Plugs.Best Et was 12.5 with a Paxton.
Old Apr 27, 2002 | 10:30 PM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
whats up guys? Im im getting that dreded code 54 as well. last summer before i went a 4 day road trip i decideed to take to GM an have them pull the codes, he said the fuel pump single was low. so a jus ignored it , took my trip, An an now this spring I still get that code., But now when im up around 3500 4th gear it tends to bog a little, an i need to play with the throtle, AN i will admit i have ran the tank realy low at times jus been lazy. What think should i jus change it out?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
