Dead In-Tank Pump - Going to External Holley Blue - Questions
Old Nov 14, 2005 | 03:16 PM
yyz28's Avatar
Ok... a little background.
The car is a former 1991 Camaro TBI car, which now has a carb'ed 383. We went with the in tank pump/3 port regulator option for fuel.
That in-tank pump has now shot craps, and I wish to install a holley blue in line pump back near the tank. I have read that I will be best served to remove the in-tank pump. So I ask the following question:
Can I simply remove the pump and reuse the existing pickup lines with the new setup, or do I need new parts for the tank itself, pickup lines, gauge sending units, etc.
Any help would be most welcome. Thanks!
Old Nov 14, 2005 | 03:56 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
take out old pump, replace with a line
Old Nov 14, 2005 | 04:24 PM
yyz28's Avatar
What type of line?
Old Nov 14, 2005 | 04:44 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
When you remove the pump you will be about 4-6 inches short of the bottom of the tank. Add some fuel line to the bottom of the sending unit to make up the difference. Also add a fuel filter in line before the pump to save the pump from crap being sucked out of the bottom of the tank.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
beachrodder
Aug 25, 2015 08:05 AM
redmaroz
Aug 16, 2015 11:40 PM
