How many miles are too many for head swap?
Old Nov 29, 2001 | 11:02 PM
Tas's Avatar
Tas
will the block deck be warped? i got 165k miles. Should I keep my heads and try porting and polishing them?
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 29, 2001 | 11:16 PM
SoCo80p's Avatar
the block will be pretty warped, new heads can be done, but just wont give you a extreamly balenced power in the engine or give as much if the deck was correct, with that many miles i wouldnt do any big projects to it.
Old Nov 30, 2001 | 09:15 AM
MD83Z's Avatar
I have 180K all me - light duty miles,and am
thinking a junkyard set of 305 heads would be fun to grind on for the exercise. I hoped that the block has survived in good shape. Is there a home test without a engine pull and machine shop?
Old Nov 30, 2001 | 10:18 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
hey tas, whether you use new heads or your old heads, you'll be in the same, or worse shape.
What I mean is that if the block deck is warped, then most likely your heads won't be flat either when they come off, so you'll end up having them milled flat anyway...same as a new set of heads.
I doubt the block deck would be "warped out of spec" anyways. Just my experience with the few builds/rebuilds I've done.
Old Nov 30, 2001 | 10:38 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i'm sure you will be in fine shape. Just when you pull the head place a straight edge on the top and record the differances between the block and straight edge with a feeler guage.
Old Nov 30, 2001 | 02:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Mine had 143,600 on it when I did the heads. No problems. Miles per se aren't the deciding factor for deck warpage, overheating or improper torquing are. Bigger issue is the condition of the rings and cylinder walls. I could see a faint cross-hatch pattern on my cylinders.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
