Valve Springs
Old Nov 14, 2005 | 10:57 PM
zrated383's Avatar
Car: '88 IROC-Z
Engine: StealthRammed 355
Valve Springs
I am buying a stock longblock and want to run a nice cam. The lift is what worries me running stock heads though. The longblock is already togeher and I am on an extremely tight budget. Is there a set of springs that will fit the stock spring perch and handle lift up to say .550 or maybe not even that much (.525 maybe). I thought I read about a set that Isky makes maybe? I do not want to start tearing apart the longblock that's already together to machine the heads. Is it possible?
Old Nov 14, 2005 | 10:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It's not the vavle springs themselves that limits the lift. It's the clearance between the bottom of the retainer and the top of the valve guide boss that creates the issue. The guide bosses need to be machined down.
Old Nov 15, 2005 | 01:47 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
but assuming that guide clearance is not an issue, yes, there are valve springs that will drop right in. SummitRacing.com lets you specify things like spring height and outside diameter in your search. But like Stekman said, springs are not gonna be the problem.
Old Nov 15, 2005 | 04:48 AM
ede's Avatar
ede
you're going to need screw in studs and if you do that cutting the spring seats isn't a big deal,
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
