vacume canister set-up....
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I just got my Jegs vacume canister, it has 2 smal holes and one big one. It came with a plug, a threaded 90* fitting, and a check valve. How do you plumb this up. I know I plug one little hole, then run from the carb to the canister then to the booster. But what hose goes to what fitting on the canister.
Pretty much what gets connected to the check valve. It only flows in one direction. So my first guess is that it goes tword the booster. just want a double check. Thanks.
Car: 91 RS
Engine: 305 Tbi (L03)
The booster already has a check valve in the vacuum line, so a second one would be redundand. Put the check valve between the carb and the vacuum canister so the vacuum canister will hold vacuum even when the car is off.
