Fixing loose valve?
Old Dec 1, 2001 | 07:07 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Fixing loose valve?
I've had an exhaust valve tapping real bad, it was not the lifter as I had already changed them and it persisted. Today I changed the valve spring hoping maybe it was weak.
When I removed the old spring, I quickly discovered the valve is real loose, lots of play side to side especially when the valve is open.
My guess is the valve guides, these heads hardly have 2k miles on them though.
My question, how can the valve guides be changed or fixed if they are too big or worn?
Can it be done with the head still on the motor?
Any links on how to do this?
Any info would be greatly apprieciated as I have never disassembled the heads before, removing the valve spring was a first today.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
[This message has been edited by 2QUIK6 (edited December 01, 2001).]
Old Dec 1, 2001 | 07:59 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
valve guide is shot. Your not burning oil???
The head has to be removed to get it fixed.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 1, 2001 | 08:37 PM
2QUIK6's Avatar
I have been using about a qt. of oil every 700-1000 miles, but the entire motor is brand new, so I didn't think it was unusal yet. But that spark plug in that cylinder was caked up pretty good with carbon and was wet when I removed it today.
Guess I'll have to tear it down again
Old Dec 1, 2001 | 09:53 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Thats where your oil was going. Gotta pull that head and send it to the machine shop. Who worked on the heads last, since you said its a fairly new engine?
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 1, 2001 | 10:25 PM
Vader's Avatar
and whatever you do, DO NOT let them knurl the guide to "shrink" the metal back into position. A replacement guide is the only way to go.
BTW - Did you get a warranty with the engine?
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Dec 1, 2001 | 10:51 PM
2QUIK6's Avatar
I was only a new ZZ4 short block. The heads were more than 15 years old, but still in the box never used in my garage for 10+ years, they are World Casting Sportsman 200s. I had them polished over the summer, and gasket matched, and the valves cut for new positive seals in preparation for the new engine build up in the Fall, which I completed back in Sept.
So, no warranty, the shop that did the head work must have either not noticed the slop in that exhaust valve, or they screwed it up.
Thanks for the info.
Now I'm trying to decide if I want to remove the SA rockers and go with non-SAs and guideplates while I have it apart again since the loose valve chewed up an alignment disk and rocker.
Old Dec 2, 2001 | 07:54 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I don't think "knurling" would even be an option w/ that much wear.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
cstrobel65
Aug 15, 2015 10:19 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
