It looks like antifreeze, but its coming out around the manifold!!
Old Dec 1, 2001 | 06:03 PM
FastAndFurious's Avatar
ok i went to change my oil today and noticed around the manifold there was what looked like antifreeze and a white bubbly substance. i almost thought something got stuck there and my have melted, but i noticed a little green liquid as well what could it be, and what can i do to fix this
Old Dec 1, 2001 | 06:07 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
If it looks like antifreeze, it probably is. It flows through the manifold and thermostat so it could be leaking anywhere. Where exactly did you see it?
91 Z28
Come see The Vicious...
Old Dec 1, 2001 | 08:04 PM
basically its just coming out of the right corner of the manifold. i just want to stop it before it becomes a problem.
oh yeah beutiful car by the way i like the contrast of the grill and the car it looks sweet!!
Old Dec 1, 2001 | 10:09 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I'm not sure what kind of engine this is, but if it is some sort of a small block chevrolet (well, actually lots of engines have some problems with this too...), it is not uncommon to have the intake gasket leak coolant at the corners (especially OEM craptastic paper gaskets ). The paper gasket material will deteriorate over time and cause some coolant to seap out at the corners of the intake manifold where it meets the cylinder head. If that is the case, you will want to do an intake manifold gasket replacement to stop the leak. If the leak isn't that bad, you may be able to just let her buck and keep an eye on the coolant level and topping it off when needed.
And if you aren't sure what the fluid is, give it a taste!! Coolant is yummy.......
Hope that helps some.....
Good Luck!
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Dec 2, 2001 | 09:20 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
<font face="Verdana, Arial" size="2">Originally posted by FastAndFurious:
</font>
If its leaking, its already a problem, no stopping it now.
Sounds like you need to replace the intake gaskets.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
AussiePr0nCar
Mar 6, 2020 04:04 PM
Tinbender59
Mar 17, 2017 10:50 AM
anesthes
42
Oct 24, 2015 07:30 PM
transaero
Aug 31, 2015 01:14 AM
Bstrang6
Aug 26, 2015 11:39 AM
