Gettin' the distributor straight
Old Dec 2, 2001 | 11:33 AM
BitchinCamaro's Avatar
Finally got my car running after the head swap, but I still got a problem. I set up the distributor had #1 and #8 forwardmost on it, but to get the car running I had to turn the distibutor about a 1/4 turn counterclockwise. (the plug wires are too short to rotate it anymore) The more I move it back the better it idles. It won't idle any less than 2500 rpm or so. I am guessing I am off teeth, but which way and how many? Thanks again for all the help, I couldn't have done it without you guys. This site kicks @$$!
-='89 Iroc-Z - 350 TPI =-
Old Dec 2, 2001 | 11:42 AM
ede's Avatar
ede
you might want to move the plug wires all one post to get more room on the wires instead of taking the distributor out. just have to remember where you moved #1 to. have you had a light on the engine? might want to check timing before you go pulling the distributor again. if you pull it put the timing marks on 6* BTDC with both valves closed on #1 then install the distributor with the rotor pointing to #1 on the cap.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Dec 2, 2001 | 12:01 PM
I am confused about moving the wires, If I move them all one post, then I will have to rotate the cap back 1 post and be back where I started right?
I do have a timming light (with the est disconnected) I cannot even see the timming mark.
BTDC is toward the passenger or drivers side of TDC?
Old Dec 2, 2001 | 12:58 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Congrats on getting it started! Another thirdgen.org success story. Warms my heart...
I can see how it could be kinda confusing, I'll try to help. What ede meant about rotating the wires was to rotate each wire over one post in the opposite direction that you're trying to turn the distributor. You rotate the whole distributor, not just the cap. By moving all the wires over one post you make it so it can be timed correctly without stretching the wires.
Rotating the dist clockwise retards the timing, counterclockwise advances it. Look closely at the timing tab. The marks that are closer to the passenger side of the car are labeled BTDC. You want the balancer mark to match up to 6 on this side of the tab when you shine the timing light on it. The side of the tab that is closest to the drivers side is ATDC which is too retarded.
Hope this helps.
91 Z28
Come see The Vicious...
[This message has been edited by ViciousZ (edited December 02, 2001).]
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
