Driveshaft / Trans Question
Old Dec 2, 2001 | 01:19 PM
GTA88's Avatar
I have trans fluid leak at the driveshaft and I noticed that the shaft is a rusty orange color, except for the quarter inch or so just before it goes into the seal. This last quarter inch is a clean metallic silver color with a thin film of trans fluid over it. I am wondering if it is because the shaft has been treated in some non-rust way there, or is it because the shaft has backed its way out of the trans about a quarter inch?. (I've heard of transmissions "walking" forward over time.)
btw, the car runs fine, just leaks some trans fluid.
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Dec 2, 2001 | 01:29 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I doubt your tranny has moved, its because the front of the driveshaft is a "slip joint" and as the rear axle moves up and down, the diveshaft slides in and out.
As for the leak, you may just need a new seal, or it could be that the "rust line" is to far up and is occasionally making contact w/ the seal chewing it up. In that case, take some emery cloth and polish it up a bit to make it smooth. Worst case scenario is the extension housing bushing is shot allowing the driveshaft to move to much inside the seal.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
